Cooling Reviews Watercooling
Arctic Liquid Freezer III 360 PRO AIO CPU Water Cooler Review – How much Pro does it really have?
With the Liquid Freezer III Pro, Arctic is launching a revised version of the popular Liquid Freezer III. In this test, we find out how the PRO version performs and what has changed. The series is intended to offer optimized premium fans and naturally retains unique selling points such as the mainboard VRM fan, the integrated cable management and the large radiator surface.
Color comes into play with the Pro variant. Not only in the selection of the 3 variants, but also in the design of the packaging. The box is not decorated with a schematic diagram, but with a picture of the AIO on the front. The back provides information on all the important details.
Inside we have the familiar picture: a molded shell for the pump and head. The radiator with pre-assembled fans, accessories and add-on parts are packed in additional layers of cardboard to absorb shocks during transportation.
In addition to the AMD bracket for installation, the accessories also include a tube of MX-6 thermal compound, various connection cables and the CPU contact frame for socket LGA1700/1851, which is also the bracket for the pump head.
Assembly and installation
With the AM5 socket I used, installation was quick and uncomplicated. The existing backplate of the mainboard is reused and supplemented on the front with its own spacers and brackets.
As with the Non PRO version, the “naked” pump block is placed on top and screwed in place. You can then decide whether to use the cable with separate control for the radiator fan, VRM fan and pump, or whether the all-in-one connection with just one plug is sufficient. In the final step, the magnetic cover is placed on top.
If, like me, you realize during assembly that your M2 cooler is too expansive, you are in good hands with Arctic. A call or an e-mail to the support team and you will be sent an Arctic M2 PRO cooler within a few days free of charge.
Specifications
Below is an overview of the key technical data. Further information can be found on the manufacturer’s product page.
Arctic Liquid Freezer III Pro 360 A-RGB, schwarz (ACFRE00184A)
Aquatuninglagernd: 25+91,59 €*Stand: 27.04.25 01:53
nullprozentshop.dein 5-10 Tagen lieferbar91,60 €*Stand: 27.04.25 01:56
notebooksbilliger.deHannover/Laatzen: lagernd (keine Online-Reservierung möglich)Onlineshop: ca. 2-4 WerktageBerlin, Dortmund, Düsseldorf, Hamburg, München, Stuttgart: nicht lagerndStand: 27.04.25 01:3391,60 €*Stand: 27.04.25 01:36
*Alle Preise inkl. gesetzl. MwSt zzgl. Versandkosten und ggf. Nachnahmegebühren, wenn nicht anders beschriebenmit freundlicher Unterstützung von geizhals.de
b
bijavay441
36 Kommentare 9 Likes
Dann besteht also der einzige Unterschied der PRO Version darin, mal abgesehen von der Optik, dass andere Lüfter auf dem Radiator verbaut wurden?
Gibt es Infos dazu, ab wann diese Pro Lüfter separat erhältlich sein werden?
Edit: Oder hat sich auch was an der Pumpe getan? Bei der Pro verbraucht diese laut Aufdruck 0,03 A mehr:
Spoilerinhalt versteckt.
Rizoma
268 Kommentare 281 Likes
Hier hat sich Arctic selber einen Bock geschossen die normale 360´er ARGB gab es und gibt es noch immer für unter 80€ warum sollte ich 30€ mehr bezahlen? Für andere Lüfter? Nope! Meine lüfter hab ich so langsam eingestellt das sie für mich unhörbar sind ca. 600-800U/min ich glaube kaum das die neuen Lüfter so viel mehr Leistung in diesen Drehzahlbereich bringen um 30€ mehr zu rechtfertigen.
PS. Hat Arctic eigentlich den Drehzahlbug der Pumpe behoben?
b
bijavay441
Im Datenblatt der Pro ist dieser, im Gegensatz zur nicht-Pro, nicht dokumentiert. Somit würde zumindest mal die Vermutung nahe liegen.
DrDre
353 Kommentare 195 Likes
Pumpenbug?
Mich würde mal ein Vergleich zwischen der LF II / III und III Pro interessieren. Ob sich ein Upgrade lohnen würde?
Rizoma
Bei der LF3 wurden bisher immer eine höhere Drehzahl ausgelesen als in Wirklichkeit anliegt
b
bijavay441
Bei der LF III wird für die Pumpe eine höhere Drehzahl zurückgemeldet, siehe Seite 2 im Datenblatt.
Enrico Steinert
4 Kommentare 7 Likes
Ich habe für euch direkt noch mal nachgefragt.
Laut Arctic wurde das Mounting leicht angepasst, um einen gleichmäßigeren Druck auf den Heatspreader zu gewährleisten und die PWM-Steuerung optimiert. Dies soll allgemein zu realistischeren Werten beim Auslesen und leiserem Betrieb führen.
Ich hoffe ich konnte euch damit weiterhelfen.
Antwort 5 Likes
RAZORLIGHT
380 Kommentare 291 Likes
Neigen die P12 Pro Lüfters wie die normalen P12 zu "Humming"?
Oder wurde das Problem behoben?
Widukind
653 Kommentare 306 Likes
Ich bleibe bei meiner A F II 420. Das schöne, wenn man sie hat. Man vergisst, dass man sie hat.
Rizoma
Das hört sich für mich nach Marketing Bla bla an. also hat sich da wohl nix geändert.
11,997 Kommentare 23,630 Likes
Ich erinnere mich noch gut an unsere Software-"Updates", wenn der Chef was Monatliches brauchte, um die Kunden von der Sinnhaftigkeit eines Wartungs- und Updatevertrages zu überzeugen. "Gesteigerte Performance", "Schnelleres Laden großer Projekte", "Diverse Verbesserungen in den Rechenroutinen", blah blah... Und damit es authentisch wirkte, wurden ab und zu noch die Icon-Sets zum Teil modernisiert und Menüeinträge "optimiert". ;D
olligo
354 Kommentare 129 Likes
Eine wirklich tolle AIO für diesen Preis und vor allem den 6 Jahren an Garantie, die Arctic hier mitliefert.
_
_roman_
180 Kommentare 57 Likes
DIe Arctic Liquid Freezer II 360 kann ich empfehlen. Die tut ihren Dienst in den einen REchner wo ich Sie verbaut habe.
Die P12 / P14 Lüfter sind günstig aber haben in 3 oder 4 Drehzahlbereiche Nebengeräusche. ES sollte jeder in der Lage sein sich eine Lüfterkurve einzustellen. Wer an so etwas scheitert. Selber Schuld.
die wärmeleitpaste mx6 war bei mir müll - der rest von arctic hat gutes preis und leistungsverhältnis.
6 jahre garantie sprechen für sich bei arctic
Theodizee
48 Kommentare 53 Likes
Schau mal auf die Arctic Seite. Die haben schon seit dem Launch der LF3 von Einführungspreisen gesprochen. Zumindest die 360er ARGB gibt's eben jetzt nicht mehr rabattiert in ihrem eigenen Shop. Non-RGB kostet 118,99 € und die RGB Version 133,99 €. Bei andern Händlern gibt's die immer noch für unter 80€, aber ich schätze mal das ist nur ne Frage der Zeit bis dort auch die Preise steigen werden. Der Arctic Freezer 36 ARGB kostet mittlerweile auch knapp an die 40€ und 50,99 € bei Arctic direkt. Gelaunched ist er für ~25€.
Die Frage ist nur ob sie tatsächlich die Preise auf ein Niveau von z.B. be quiet heben wollen. Die Endorfy Navis F360 performed ebenfalls ziemlich gut und kostet auch 80-90€. Falls Arctic Preise über 100€ durchsetzen will, ist die Navis F360 wohl dann die neue Nr.1 bei Budget AIOs.
Rizoma
Das war kein Einführungspreis sondern ihr 23 Jähriges Jubiläums Angebot. Und das galt so lange das jemand der eine AIO wollte schon lange zugeschlagen hat. Und die, die noch nicht zugeschalgen haben, werden im Handel noch einige zeit die u80 erhalten. Es gibt also keinen einzigen Grund die Pro zu kaufen.
Lagavulin
306 Kommentare 261 Likes
Die Pumpe der LF III scheint mir leiser zu sein als die der LF II, aber das ist natürlich eine höchst subjektive Einschätzung.
Der größte Vorteil der LF III gegenüber der LF II ist m.E., dass man nun endlich die Pumpendrehzahl auslesen kann (auch wenn diese um ca. den Faktor 1,5 zu hoch angezeigt wird – Arctic liefert dazu Drehzahlkurven (angezeigte vs. tatsächliche Drehzahl) im Datenblatt.
Bei der LF II waren die Schlauchanschlüsse noch auf der rechten Seite, bei der LF III sind sie unten. Das hat den Nachteil, dass man beim Tausch der SSD im obersten Slot den Kühler abnehmen muss, da er den Slot überragt (zumindest ist das das bei meinem Asus Crosshair Hero so). Beim Neubau eines Systems sollte man also daran denken, erst die SSD einzusetzen, bevor man den Kühler montiert. Insgesamt sind das für mich aber Kleinigkeiten.
Mit der LF III bin ich bezüglich Kühlleistung und Lautstärke der Pumpe auf einem Ryzen 7950X sehr zufrieden. Ein Upgrade auf die LF III Pro kommt für mich allerdings nicht in Frage, da ich die Arctic-Lüfter gegen Noctua NF-A12 getauscht habe.
Dragon of Luck
199 Kommentare 162 Likes
Ab und an lohnt auch ein Blick in die B-Ware von Arctic - Ich hab meine LF III 240 A-RGB für 45 Euro gekauft - der Karton war noch Originalversiegelt.
Also lediglich ein Rückläufer.
Arctic sorgt bei geöffneter Ware aber auch dafür, dass diese wieder vollständig ist.
Widukind
Wozu muss ich denn etwas auslesen? Ich will der AiO nichts zu tun haben. Und auch nicht hören. :D
Ich würde nach Möglichkeit versuchen eine AiO mit 140er Lüfter zu nehmen. Die sind idR deutlich leiser bis lautlos bei ~450rpm.
Enrico Steinert
