Artificial Intelligence Gaming GPUs Graphics Reviews
AMD Radeon RX 9070XT and RX 9070 review – They’re back and even available, thank goodness!
AMD has finally thrown down the gauntlet with the Radeon RX 9070 and 9070 XT, taking direct aim at the recently launched GeForce RTX 5070 from NVIDIA. While the RTX 5070 has to make do with 12 GB of GDDR7 memory, AMD consistently relies on 16 GB of GDDR6 and prices both cards at a competitive 629 and 689 euros RRP respectively, although the prices of the board partner cards could certainly reach various heights here too. However, this not only counters the RTX 5070 launched yesterday, where the board partner cards often cost well over 800 euros, but also comes dangerously close to the RTX 5070 Ti for a street price of well over 1000 euros in some cases – albeit without the blessings of DLSS 4 and Frame Generation, but with solid raster performance and FSR 4.
NVIDIA was the first to deliver, but the problem is well known: Blackwell cards are once again in short supply and rather scarce on the market for the already ambitious prices. Meanwhile, AMD has obviously been able to hold back chips and cards for two months in order to flood the market with sufficient availability and attractive RRP. The calculation is simple: those who want more VRAM and solid performance for less money should probably take a closer look at the 4X 9070 XT, and those for whom the RT 5070 offers too little memory may be tempted by an RX 9070. It remains exciting to see whether NVIDIA can counter with the next drivers or an early super refresh – or whether AMD may even finally hit the nerve of buyers again with a slight lead.
And of course I hope that the MSRP (Manufacturer’s Suggested Retail Price) doesn’t become a “Massively Surpassed Real Price” here, because the actual price has so far mostly been somewhere between “outrageous” and “astronomical”. Alternatively, we can view the current prices as “Maybe Someday at a Reasonable Price” and simply wait a little longer. Of course, many people find this difficult, but it’s also possible, just take my word for it.
Important preface to the sample selection, benchmarks and conclusions
AMD has made it easy for itself this time and completely dispensed with its own reference design. In itself, this would not be a problem if the board partners did not almost without exception rely on factory overclocked models for sampling – and of course not without reason. After all, you want your own cards to look as good as possible, and if AMD itself does not contribute a standard card, testers have little choice but to work with what is provided.
However, this brings with it a practical problem: while it is at least theoretically possible to reproduce a reference clocking for NVIDIA cards using software, there is not really such a precise option in the Radeon software. So you can’t simply “activate the reference values” and make a fair comparison. Sure, you could throttle the power consumption to a reference value, but then it would be a bit skewed when it comes to the clock rate at the latest. In addition, due to a lack of time, it was simply not feasible to retest every NVIDIA card in an overclocked version – that would go beyond the scope in terms of both time and technology. However, I have included a simple comparison in WQHD in the summary, which compares the four currently competing cards with and without OC.
In order to make at least a halfway representative selection, I have chosen two of my four test samples that probably best reflect the real situation. The choice fell on the Sapphire RX 9070XT Nitro, because the XFX RX 9070 XT Mercury ran at up to 3.4 GHz in my tests – a full 400 MHz above the boost clock specified by AMD, until it unfortunately broke. So I reset everything to zero and tested it again. The XFX RX 9070 Quicksilver completes the test field so that XFX doesn’t go away completely empty-handed. In terms of performance, it is on a significantly higher level than the Sapphire Pulse, so I ended up testing two real OC cards. But here, too, I was hit by the defect witch, which is why the volume values of the XFX RX 9070 Quicksilver are missing at the end.
Incidentally, the error pattern was the same for both cards. When starting Cyberpunk 2077 in Ultra HD, the monitor already lost the signal in the intro after a brief high-pitched coil beep. After a reboot, only the HDMI connection was still working and only as a basic adapter, the display port was completely dead. I am in contact with XFX and at least the XFX RX 9070 XT Mercury has been replaced in the meantime. I hope that I’ll be able to write an individual review soon.
When we see the cumulative performance values later, we’ll have to mentally deduct around 5 to 10% performance or give the NVIDIA cards around 5% more. Because the 10% increase in performance that NVIDIA repeatedly mentions can only be achieved with simultaneous and hard-core RAM OC. And even if you were to do this math – I can spoil it right now – it could be that one or the other card could probably use a new price point. But nothing should be left on the shelf that doesn’t get there in the first place.
However, I can promise you that I have planned to test all the working cards, as well as the Blackwell cards that are still outstanding, once again as individual tests. Of course, I won’t go into the usual theoretical part at this point, as there were already two articles on this last week. One was the long version and the other a very short version, both of which I have linked to you again:
The Sapphire RX 9070 XT Nitro 16 GB
The Sapphire RX 9070 XT Nitro 16 GB weighs 1863 g (1953 g with adapter) and offers not only performance, but also some interesting design decisions. The solid light metal cooler with an installation length of 33 cm and with attached perforated metal gives the card a unique look, even if the mesh is purely decorative. It plays no role in terms of cooling, but ensures a high-quality appearance. Despite its 13.5 cm installation height and 6 cm installation depth (plus 0.5 cm backplate), the card looks relatively compact and compact. In the end, it looks smaller than it actually is.
The Sapphire RX 9070 XT Nitro 16 GB offers a well thought-out connection layout that is geared towards both classic monitor setups and modern requirements. There are two DisplayPort 2.1 ports and two HDMI 2.1a ports on the slot bracket. The card is therefore ideally equipped for high-resolution displays with high refresh rates and supports VRR as well as 4K and 8K outputs with DSC (Display Stream Compression).
A special detail is the magnetic, removable backplate. It only sits on top and reveals another cover underneath – the board itself remains hidden. Nevertheless, it has a functional use, as it covers the 12V HPWR connection at the rear.
Although this is a neat visual solution, it also means that the cable has to be fed under the backplate before it can reach the connection. The flip header ensures that the cable is routed to the rear, which makes cable management much easier and ensures a tidy appearance in the case. Unfortunately, the header does not leave a tactile and acoustic feel when it clicks into place, which is actually intended according to CEM 5.1. The adapter holds securely when plugged in, but you really have to check it carefully.
In addition, Sapphire installs an ARGB interface, which can be used to synchronize the lighting. Technically, Sapphire remains true to itself and delivers a powerful, factory overclocked card with an efficient cooling system and high build quality. More on this in the detailed individual review with detailed measured values for temperatures, noise and power consumption. Here is at least the GPU screenshot of the tested card, which shows that 90 MHz more have already been applied ex works, although even this is far exceeded.
The XFX RX 9070 Quicksilver 16 GB
The XFX RX 9070 Quicksilver 16 GB is a card weighing 1520 g, which despite its 34.5 cm length, 12.5 cm installation height and 6.5 cm installation depth (plus 0.5 cm backplate) is pleasantly unobtrusive and consistently focuses on functionality. No excessive bling-bling, no exaggerated RGB staging – instead there is a simple yet striking plastic look with piano lacquer accents as a fingerprint card. So if you’re looking for a GPU that doesn’t light up like a Christmas tree, this should be just right for you. You usually have a microfiber cloth in the house.
In terms of cooling technology, XFX relies on a massive three-fan design with a large-area radiator construction which, in combination with several heat pipes, ensures even heat distribution. The fins of the heat sink are aligned in such a way that they optimally direct the airflow and efficiently transport the waste heat away from the card. Despite the massive design, the card still remains in a frame with around 2.5 slots (for mounting), which fits into most systems without major space problems.
The XFX RX 9070 Quicksilver 16 GB is not only visually discreet, but also down-to-earth in terms of technical features. This is particularly reflected in the connections. There are three DisplayPort 2.1 and one HDMI 2.1a connection on the slot bracket. This means that the card is ideally equipped for the latest monitors and high refresh rates. DisplayPort 2.1 enables high resolutions with high frame rates, and DSC (Display Stream Compression) allows data rates to be managed efficiently without any visible loss of quality.
An interesting difference to other RX-9070-XT models can be seen in the power supply: instead of relying on the new 12VHPWR connector, XFX uses two classic 8-pin connectors (6 2 pin). This is a clear advantage for anyone who doesn’t want to use adapters or special power supply units. Plug it in and you’re done – without having to worry about potential melting problems or cable routing.
Another interesting feature is the dual BIOS switch, which can be used to switch between two profiles, one of which has reduced fan speeds for quieter cooling. This makes the card flexible, depending on whether you want to squeeze out the last bit of performance or simply have a GPU in the system that is as inconspicuous as possible. The Quicksilver therefore remains a card for purists: no unnecessary bells and whistles, but a robust power supply, a solid cooling system and a good variety of connections. More on this in the detailed individual review with detailed benchmarks and measured values for temperatures, noise and power consumption.
The clock rates are also not without merit: in my tests, the Quicksilver boosted stably up to around 3 GHz, which is well above the specifications stated by AMD (and still has room for improvement). XFX does not hold back with aggressive overclocking specifications, but the card remains pleasantly quiet. The fan profile is designed rather conservatively so that no unpleasant noises are produced even under load. When idling, the fans are of course completely silent. And so the XFX RX 9070 Quicksilver 16 GB remains a well thought-out card for all those who don’t need an exaggerated RGB show, but simply a powerful and well-cooled GPU with solid workmanship. I would also like to draw the attention of attentive readers to the PCIe version, as the card only ran with the default Gen4 with riser card. On the right you can see the screen of the defective card, without riser and in the second, identical test system
Comparison table of the technical data (reference)
Specification AMD Radeon RX 9070 XT AMD Radeon RX 9070
Architecture RDNA 4
Manufacturing process 4 nm
Number of transistors 53.9 billion
Chip size 357 mm²
Compute units (CUs) 64 56
Ray Accelerators 64 56
AI Accelerators 128 112
Stream processors 4096 3584
Game GPU clock 2400 MHz 2070 MHz
Boost GPU clock Up to 2970 MHz Up to 2540 MHz
Peak FP32 computing power 48.7 TFLOPS 36.1 TFLOPS
Peak FP16 computing power 97.3 TFLOPS 72.3 TFLOPS
INT8 AI performance Up to 779 TOPS with sparsity Up to 578 TOPS with sparsity
INT4 AI performance Up to 1557 TOPS with sparsity Up to 1156 TOPS with sparsity
Peak texture fill rate 730.3 GT/s 564.5 GT/s
Render Output Units (ROPs) 64
Pixel fill rate 190.1 GP/s 161.3 GP/s
Infinity Cache (3rd Gen.) 64 MB
Memory size 16 GB GDDR6
Memory clock 20 Gbps
Memory bus 256-bit
Effective memory bandwidth 640 GB/s
PCI Express interface PCIe 5.0 x16
Board Power (TBP) 304 W 220 W
Recommended power supply power 750 W 650 W
HDMI 2.1b
DisplayPort 2.1 (UHBR13.5)
303 Antworten
DMHas
103 Kommentare 55 Likes
Schöner Artikel! AMD hat alles richtig gemacht.
@Igor Wallossek: Sind die Temperaturangaben der Sapphire korrekt?
(Die Differenz oder die Hotspottemperatur dürfte nicht stimmen:
... Sapphire RX 9070 XT Nitro+ liegen mit 57 °C für die GPU und maximal 85 °C für den Hotspot auf einem angenehm niedrigen Niveau, insbesondere angesichts der Leistungsaufnahme von 345 Watt. Das übliche Delta von 18 Kelvin zwischen GPU und Hotspot bestätigt)
12,408 Kommentare 24,646 Likes
Danke, ja, es sind 28°C. Die Hektik... Ist gefixt.
Antwort 4 Likes
Cerebral_Amoebe
143 Kommentare 68 Likes
Vielen Dank für den Test!
Hier habe ich etwas gefunden:
SchmoWu
113 Kommentare 38 Likes
Danke für den Test @Igor Wallossek
auf Seite 10 steht auch nochmal 18Kelvin.
mfg
Schmo
:edit
auf Seite 10 hast du die 9070Pulse mit Manual UC mit in der Liste, wie schneidet die mit Werkseinstellungen zur 9070Quicksilver ab? Wird sich nix nehmen?
kodos
21 Kommentare 13 Likes
Die ersten 5070 sind im Handel und die billigste ist 790€
Damit ist die 9070 trotz gleichen UVP Konkurrenzlos wenn sie morgen zu eben diesen zu bekommen ist
Gurdi
1,546 Kommentare 1,108 Likes
Mega Karten. Die werden den Markt ordentlich durchschütteln. Wenn nur die gierigen Händler derzeit nicht wären.
Antwort 4 Likes
Widukind
653 Kommentare 310 Likes
Sehr spannend! 🙂 (y) Vielen Dank!
Die starke RT-Leistung hatten wir ja vermutet. Aber auch die starke Rasterleistung etwa gleichauf mit de 7900XTX überrascht mich schon sehr.
Die 5070 könnte zur neuen 4060 TI werden. :D
Bei dem Angebot von AMD. Potentielle 4070TI S Käufer als auch preiswusste 5070TI Interessenten werden jetzt zu AMD's 9070XT abwandern.
Antwort 5 Likes
Gurdi
Habs doch gesagt^^
Widukind
Du hattest wohl Insider-Einblicke... ^^ Bei den technischen Rohdaten hat mich das nun wirklich verwundert. Aber um so besser! Kommt endlich mal etwas Schwung in den Markt! :cool:🙏
t
teenlaquifah
1 Kommentare 0 Likes
Dann gucken wir mal morgen auf die Preise und die Verfügbarkeit
b
bitracer
749 Kommentare 336 Likes
Notwendige Bedingung für Hype:
Leistung der vorherigen Flagschiffkarte "eingestellt" (==gleichgezogen!) // so soll es ja eigentlich auch laufen!
Hinreichende Bedingung:
"vernünftige" (==leise und haltbare) Karten für msrp verfügbar ? ? ?
...wir werden es ja morgen sehen können.
Falls das so klappt, dann "Hut ab, AMD!"
Wenn nicht...
...warten bis zum Abverkauf in 12..24 Monaten :cool:
RX480
2,138 Kommentare 1,029 Likes
macht sich auch besser für den Hotspot
evtl.
sollte man wg. der geringen Fläche die grooooßen Customs beim OCen mit PL+15 mit Kryosheet betreiben
könnte sein das PTM9750 nicht reicht
Wieviel PL +/- Prozent lassen sich denn einstellen?
Case39
2,690 Kommentare 1,057 Likes
Danke an igor für das wie immer detaillierte Review und DANKE an AMD zum abliefern dieser Karten....feiere ich gerade.
Bitte fürs nächste Jahr ne High End Karte...hab die Nase voll von NV und deren "Lesswell" Karten.
Antwort 6 Likes
M
Mudsee
101 Kommentare 65 Likes
Was micht wundert gibt es keine verschiedene Biose mehr (Einstellungen) ? Bei der alten warfen es ja 2/3 Silent , Normal , OC. Das konnte man ja entweder manuell bzw mit der Softwäre einstellen
Das mit dem Stecker ist so ne Sache bei der Nitro, gerade das mit dem fehlenden feedback ist so ne Sache.
Das mit XFX hmm 2 Karten beide defekt ist finde ich nicht so gut. Da frägt man sich wie der rest im Handel so ist.
grimm
3,572 Kommentare 2,618 Likes
Sehr nice. Im Prinzip kriegt man ne 4080er für um die 800,- Euro. Das ist vergleichsweise fair.
Antwort 5 Likes
Widukind
Im Prinzip sogar eine 4080S mit 4070TI S RT-Leistung. FSR statt DLSS, aber das kann man bei dem Preis verschmerzen. Bei Nvidia bist Du bei der Leistung bei 1000-1100€ und da hast Du dann noch kein 3,5-Slotdesign mit dickem Kühler.
c
carrera
253 Kommentare 163 Likes
wenn ich aus dem Artikel zitieren darf
"Und ich hoffe natürlich, dass hier der MSRP (Manufacturer’s Suggested Retail Price) nicht zu einem “Massively Surpassed Real Price” wird, weil der tatsächliche Preis bisher meist irgendwo zwischen „unverschämt“ und „astronomisch“ liegt. Oder aber wir betrachten die aktuellen Preise eher als “Maybe Someday at a Reasonable Price” und warten einfach noch ein bisschen. Das fällt vielen natürlich schwer, geht aber auch, glaubt es mir einfach."
@Igor Wallossek: das ist einfach großartig - you made my day 😂
grimm
Die "S" ist auch nur so ein Unfall. Meine GameRock OC ist easy auf "Super"-Niveau.
Antwort 4 Likes
R
RX Vega_1975
642 Kommentare 108 Likes
Was wird die 9070 XT Gigabyte OC reissen
und die Asrock Stealth Legend 9070 XT
und auch kosten bitte ...
@Igor Wallossek weisst dies bereits ?
Follow Igor:
