GPUs Latest news
AMD FSR 4 on RDNA 3: a double-edged sword
A resourceful Reddit user called “Virtual-Cobbler-9930” took the plunge: he activated AMD’s brand new FSR 4 on a Radeon RX 7900 XTX – an RDNA 3 card that does not officially support FSR 4. AMD had cleverly reserved the upscaling hammer exclusively for RDNA 4 GPUs – allegedly because of the AI/ML architecture. But even without official support, RDNA 3 shows interesting results: higher image quality and FPS in some cases compared to FSR 3.1, although hardly any native 4K performance.
The benchmarks – facts instead of marketing hype
Cyberpunk 2077 @4K, FSR Quality:
  • FSR 4: 56.3 FPS
  • FSR 3.1: 85.1 FPS
    The picture quality in FSR 4 was visibly better – but faster? Only in comparison to the original, not the previous version. RDNA 3 gains slightly in BQ, but loses massively in speed.
Source: Reddit
Oblivion Remastered:
  • FSR 3.1 brings more frame rate, but artifacts. FSR 4 cleans up the image, but costs around 20-30% performance – if you want to smooth, you pay with speed (and can counteract this with “Balanced” or Frame Gen).
  • Marvel’s Rivals (e-sports):
  • FSR 4 = 41 FPS
  • FSR 3.1 = 74 FPS
    HSR-typical: Quality yes, but with fast games like e-sports it comes at the expense of performance. RDNA 3 has a very hard time with FSR 4 – gaming is almost a capitulation to technology.
One user on Reddit sums it up correctly:
“…FSR4 Quality preset do gain additional FPS at 4k, compared to plain native…, but that gain could be almost nullified at lower resolutions like 1080p. Simply because RDNA3 can’t push higher fps with FSR4 due to architecture.”
Technical-strategic classification
FSR 4 is based on ML/AI – this is due to the architecture of RDNA 4. RDNA 3 lacks this dedicated AI core. FSR 4 therefore has to run in a roundabout way: less efficient, more load. It is reminiscent of a diplomatic capitulation – the technology is used, but incompletely. Users give the image a thumbs down, but the smell of the lack of AI is still noticeable. Strategically, AMD’s maneuver is clever and RDNA 3 users will be pleased, but it remains a double-edged sword. AMD is showing its FSR-4 potential on older hardware – generating hype. But at the same time it shows its limits: Native performance gains can only be achieved with the next generation.
For whom is FSR 4 on RDNA 3 worthwhile?
  • Pro: Significantly better picture quality than FSR 3.1, visibly fewer artifacts.
  • Cons: Massive performance losses compared to FSR 3.1, little added value on lower resolutions (e.g. 1080p).
If you’re chasing 4K with maximum BQ and are a patient hobby modder, you can take a chance on FSR 4 – but this is more of a diplomatic playground than a lean production solution. For ambitious gamers – especially with eSports or action-heavy titles – FSR 3.1 or the native performance remains the buttery-soft choice.
Source: Radeon, imgur
LEIV
1,635 Kommentare 694 Likes
Wird auch irgendwo erklärt, wie das funktioniert? Das ganze würde mich vor allem mal auch auf RDNA 3.5 interessieren 🤔
Bildvergleich Nativ vs FSR4 wäre auch noch interessant und ob man überhaupt mehr FPS als Nativ bekommt?
RX480
2,138 Kommentare 1,029 Likes
Thread lesen:
CachyOS ist inzwischen verbessert, so das nix am Kernel mehr gehackt werden muss, nur die dll und ggf. ein command
nutzen.
In dem Thread ist auch ein User mit ner 7900xtx.
S
Supie
196 Kommentare 45 Likes
Mich würde mal interessieren, da war doch mal was, das jemand FG auch auf RTX 2700 (oder waren es 3700 Karten? schon so lange her...)Karten lauffähig gemacht haben wollte....?
Da kam aber nix mehr....
RX480
ab FSR3 oder 3.1 geht Das
also schon lange
S
Supie
ich meinte natürlich DLSS wenn ich von NVIDIA spreche, dachte das wäre selbstredend.....
RX480
Du kannst ab FSR3.1 das DLSS nehmen und trotzdem geht das AMD-FG.
Das ist ja das Schöne, das man FG getrennt benutzen kann.
S
Supie
Und wie ist das Ergebnis beim FG soweit mir bekannt, kommt es nicht an die NVIDIA Qualität ran.....
Dann hat man zwar das Argument, das es verfügbar ist, aber hier ging es mir um die Machbarkeit, die laut
einiger Artikel angeblich machbar gewesen sein soll, damals - durch einen Hack oder was auch immer.....
RX480
Ne 2070s/3080 hat kein NV-FG aber mit AMD-FG kannste halt länger mit der ollen Hardware leben.
Mit Optiscaler gehts vllt. auch für Games zu erzwingen, wo noch nicht FSR3.1 drin ist.
(musste dann nachlesen, ob noch irgendeine spezielle dll zusätzlich reinkopiert werden muss, ... Nukem mod)
mit der 2070s/3080 ist ja immer noch genügend Rohleistung da
(solange der Vram gerade noch so für FG reicht, einen Versuch wert)
S
Supie
Früher, ode später wandert eh eine neue Karte in meinen Rechner. Da mach ich mir jetzt kein Kopf mehr um FG etc....
Samir Bashir
As a trained electrician, he's also the man behind the electrifying news. Learning by doing and curiosity personified.
