GPUs Graphics Reviews
Sapphire 7970 Toxic GHz Edition 6 GB and Eyefinity special with 6 monitors | Retro
Sapphire provides the new flagship 7970 Toxic GHz Edition with a full 6 GB of video memory and uses one of the new Tahiti XT2 chips, which is even clocked with 1.2 GHz thanks to “Lethal Boost”, as long as the card runs within the thermally intended limits. The then higher RAM clock of 1600 MHz also promises a rich gain, always provided you find a worthwhile task for this constellation. Reason enough to test this card especially in the high resolutions and to question whether this enormous memory expansion brings any added value at all.
What could be better for this than Eyefinity 6? But stop! Almost everyone will now object at this point that you need a special Eyefinity edition of the HD 7970 for this, as long as you use simple monitors with DVI input, because the conventional cards don’t have enough outputs. This is true in principle, but it is still wrong. We will namely show how you can very well create an Eyefinity landscape of extra width with 3 splitters and whether only a graphics card is even capable of moving the enormous pixel heaps quickly enough. We also don’t want to forget the test where we question the added value of the double-sized memory. Quite an extensive program, some of which we have outsourced to other venues in the form of a public event.  The new Sapphire card has to prove itself against the already tested Gigabyte 7970 Windforce 5X, which we only overclocked to 1.2 GHz this time to test a direct comparison model with 3 GB memory expansion.
Technical data and details
Sapphire has used AMD’s Tahiti XT2 for the 7970 Toxic and thus also the TDP limiter introduced with the GHz Edition via the clock reduction when the load or temperature is too high. Whether this decision was really wise, we will find out later. First, let’s look at the sober facts about the card. With a memory expansion of 6 GB RAM and clock rates of up to 1600 MHz, you first use what is currently technically feasible with full hands.
The technical parameters are now revealed in the tabular overview:
  Sapphire 7970 Toxic
GHz Edition
Gigabyte 7970 SOC
Windforce 5X
Radeon HD 7970
GHz Edition
Radeon HD 7970
Stream processors 2048 2048 2048 2048
Texture units 128 128 128 128
Full Color ROPs 32 32 32 32
GPU clock Standard:
1050 MHz Base
1100 MHz Boost
“Lethal Boost”:
1100 MHz Base
1200 MHz Boost
1080 MHz 1000 MHz Base
1050 MHz Boost
925 MHz
Texture fill rate 140.8 MHz Gtex/s
153.6 Gtex/s
138.2 Gtex/s 134.4 Gtex/s 118.4 Gtex/s
Memory clock 1500 MHz
1600 MHz
1375 MHz 1500 MHz 1375 MHz
Memory bus 384-bit 384-bit 384-bit 384-bit
Memory throughput 288 GB/s
307.2 GB/s
264 GB/s 288 GB/s 264 GB/s
Graphics memory 6 GB GDDR5 3 GB GDDR5 3 GB GDDR5 3 GB GDDR5
The size 365 mm²
Transistors in billions 4,31
Structure size 28 nm
Power connections 2 x 8 pin 2 x 8-pin 1 x 8-pin, 1 x 6-pin 1 x 8-pin, 1 x 6-pin
Power consumption
maximum (TDP)
320 watt 300 watt 275 W 250 W
a
alexbirdie
26 Kommentare 8 Likes
Toller Artikel.
Aber:
Ich vermute, der Originalartikel stammt ca. aus dem jahre 2013 und ist keineswegs neu.
Egal, ob Reprint eines alten Artikels oder neuer Test, ich kann nicht nachvollziehen, was ich heutzutage mit dem Test einer so alten Grafikkarte anfangen soll.
ipat66
1,538 Kommentare 1,605 Likes
Vielleicht bist Du noch zu jung,um den Charme alter Artikel zu erkennen....
Es zwingt Dich ja niemand,jeden Artikel zu lesen ?
Wer eine solche Karte in Betrieb hatte,erinnert sich,wenn er es denn möchte,an alte Zeiten....
Auf der anderen Seite,darf man auch nicht vergessen,dass es sich bei Igor's Lab nicht um eine Multinationale Gesellschaft,sondern um eine kleine eingeschworene Gemeinschaft mit begrenzten Mitteln handelt.
Ab und an ein kleiner Ausflug für die Nostalgiker ohne viel Aufwand...
Wieso nicht ?
Ansonsten gibt es genug neuere Reviews,welche man sich nochmals genauer anschauen kann...
Ich sage es nochmal anders:
Danke Igor mitsamt Team für Eure Arbeit und Euren Enthusiasmus!
Antwort 4 Likes
v
vonXanten
831 Kommentare 364 Likes
@alexbirdie ja ist ein Retro Artikel, steht auch dabei als letztes | Retro. Diese gibt es meist am Wochenende.
Danke Igor für den Rückblick, hatte bzw. habe nur die HD 7770 aus dieser Serie genutzt als Crossfire Duo bekommen.
konkretor
352 Kommentare 365 Likes
Mit dem 6 GB RAM sollte es heute für fhd noch gut gehen.
11,656 Kommentare 22,540 Likes
Der Artikel ist fast auf den Tag genau 10 Jahre alt. Ich finde die alten Sachen übrigens durchaus interessant, weil sie zeigen, dass Vieles heute gar nicht so neu ist, bis hin zum 5-Slot-Kühler und riesigen Spezial-Caps bei der GPU-Spannungsversorgung. Naja und es sind mittlwerweile viele Leser dazu gekommen, die diese Artikel nicht kennen (können).
Und selbst CB macht ja nichts anderes und erinnert sich (trotz vieler Festangestellter) gern an alte Tage. Ich arbeite das Wochenende durch für den Artikel am Die und Mi. Ob Monatg was kommt, liegt am meiner Ausdauer oder den Umständen, dass auch beim Team immer mal was dazwischen kommt. :)
Antwort 5 Likes
Genau das tut sie auch. :)
D
Dark-Noir
14 Kommentare 3 Likes
Wollte ich mir damals auch kaufen, allerdings war es mir den Aufpreis zur 3GB Variante nicht Wert.
Da ich mir gedacht habe bevor die 6GB für mich relevant werden habe ich eh eine neue und so war es dann auch am Schluss.
Meine 7970 hat den Geist aufgegeben bevor mehr als 3GB relevant gewesen wären 😅
c
cunhell
610 Kommentare 588 Likes
Meine Asus R9-280, was ja quasi eine 7950 ist, werkelt immer noch, allerdings nur mit 3GB RAM. Leider ist der Orginalkühler hin und der Aftermarket hat leichte Probleme sie zu kühlen. Mir der Karte geht mehr als man erst mal glauben will.
Cunhell
T
TheSmart
501 Kommentare 263 Likes
Hmm der Artikel könnte auch noch in der heutigen Zeit Bestand haben. Als ich den Test und vor allem das Endfazit gelesen habe musste ich mich spontan an die 3090 Ti erinnern.
Säuft auch zu viel, Leistungsplus hält sich derweil in Grenzen bzw kann man nicht viel anfangen, Preis zu hoch angesetzt und hört sich wohl teils wie eine kleine Flugzeugturbine an (Ich habe da schon einen Dirt Devil, der sich so anhört und nein das ist keine Graka).
O
Ozzy
225 Kommentare 137 Likes
Alles gut, ich finde das auch sehr spannend. Das Retro zeigt es zwar an, aber ein: Der Originalartikel erschien am xx.xx.xxxx darunter wäre schön, wenn das machbar ist.
B
Brutek
6 Kommentare 0 Likes
Interessanter Artikel, auch wenn er nicht aktuell ist, befindet er sich am Puls der Zeit.
Die 7970 war früher einfach der Hammer, mit ordentlichen Reserven. Die 6GB Variante, damals absoluter nonsens. Hatte man doch die schnellste Karte bei der schon 3GB als unfüllbar galten. Hatte man nun eine Karte die mit der man gute 8 Jahre problemlos noch vorne mit dabei war.
Hätte man damals eine Karte die so alt war, war sie schon 5 Jahre für nichts mehr zu gebrauchen. Das ändert sich hier. Die 7970 6GB ist für mich, neben der Titan, eine der ersten Karten die 10 Jahre zu gebrauchen sind. Wenige haben das erkannt. Du anscheinend schon. Ich erkenne dir das hoch an. Danke Igor.
MeinBenutzername
214 Kommentare 75 Likes
Ich finde es auch nicht verkehrt auch mal ältere Dinge präsentiert zu bekommen, somit kann man auch mal erfahren was sich so alles verändert hat und welche Leistungswerte die Karten damals aufgewiesen haben. :)
a
alexbirdie
Ich mußte lächeln bei deinem Beitrag.
Warum?
Ich werde 66 und hatte früher auf meinem 3770k-Rechner selber eine 7970. Die ist dann irgendwann eingegangen und wurde durch eine 390x ersetzt.
ipat66
Mit 66 Jahren.....​
Da gab es doch mal ein Lied von Udo …
Dann bist Du vielleicht kein Nostalgiker?
Immerhin hat es für ein Lächeln gereicht!
a
alexbirdie
Weiß ich nicht. Teilweise ja, teilweise nein.
Technisch habe ich natürlich alle Entwicklungen mitgemacht, und damit meine ich alle Technik-Bereiche(Telefon, Hifi, Computer , Autos etc.).
Ich bin vielleicht ein wenig abgeklärter, da ich mein ganzes Leben lang im IT-Bereich gearbeitet habe.
Bei anderen Bereichen denke ich mir manchmal schon, daß es früher besser war. Ist natürlich zum jetzigen Zeitpunkt topaktuell, wenn ich mir die jetzigen Hauptprobleme der Menschheit und der Welt anschaue.
t
tommy7110
23 Kommentare 1 Likes
Würde mir offentsichtlich erstmal für mein gemeinnütziges Projekt schon genügen,
Follow Igor:
