I've got the xfx 6900xt speedster merc 319. I've installed the latest morepowertool to adjust the voltage (min voltage 618 and maximum voltage to 1050, fo GFX and soc) those settings are working stable in my soft powerplay tables and the next step was making a proper bios.
I have extracted the bios with the latest GPU Z, but the latest red bios editor is unable to edit the file and add the .mpt values. I cant edit the name or anything. Also when im using amdvbflash 3.04+ it is complaining that the adapter can't be found. When I use the latest amdvbflash from techpowerup, the adapter is showing but its complaining that a "check" isnt working.
I've tried both versions in Windows, and linux, no luck.
attached is the unmodified bios if somebody wants to check if its different to others (bios switch closer to the displayports, away from the 8pin power connector). I think that is the balanced/OC bios and the other position is the low power bios.
I've also attached the .mpt file, created with more powertool 1.3.7 beta10.
Is that what rbe is supposed to look like after loading the stock bios? everything is greyed out.
