Hi Does anyone have experience with 8GB hynix RX580s ? I've done a bios mod on the card where I copied 1500 straps over to the straps below. I am currently mining rvn which is pretty much uses eth overclock. Here is my setting:
My rig consists of 5 other cards which are 4G are are stable at 14mhs. Those cards are also bios modded and settings used are as follows:
Is the VDD for the 8G too low is that the issue ? Any advice would we welcome. Thank you.
