Hi guys,
Im having issue with my brand new RX 5700 cards and actually cant understand how to approach it.
Generaly i want to unlock the memory and put the clocks as high as possible.
I have RTX 2060 6GB GDDR6, and RX 5700 8GB GDDR6. I use them both for mining and on one algo (argon2d) they do the same 360kh (RTX with full OC +950 MHz on memory, +100 on clock). Yet on eth RTX does 32MH (full OC), and RX 5700 does 55 .. (no OC!) I'v read that RX cards have locked clocks. I was wondering if it is an issue with miner / algo (argon2d / eth) or the card is locked? In about to use More Power Tool where i would like to unlock clocks. I've already saved raw BIOS via Saphire TriXX.
I should be able to put in max mem field: 1750? (14,000 / 2 = 7,000 / 2 = 1,750?)
RTX
RX:
RTX
RX:
