GoGoGigabyte
- Mitglied seit
- Aug 20, 2021
- Beiträge
- 6
- Bewertungspunkte
- 2
- Punkte
- 2
Hello. I have some questions:
- I have a reference 6700xt under constant light load in windows, that is downclocking core when it reaches 78oC current temp/80-81oC hotspot temp..is there is a way to change this limit using this using MPT? If temp drops it will recover clock automatically..However why is this limit at that temp? I want to change it because the reference cooler is trash, even at full speed it's not efficient to move the heat (under 100w but hot sealed room)
- I heard now you can unlock vcore limit and vram clocks on even reference 6900xt? How to do it and what driver i need to use?
- Is there documentation anywhere for all features/option available in MPT for Rdna 2/Navi 2x cards?! I know the basic ones but i need documentation for the rest
Thanks
