Question Possible newer version of AMDVbFlash - 3.15
TwistedKestrel
Hi all,
It was suggested on Reddit that this was a good place to post this, so here I am. It seems that this is a newer version (3.15) of AMDVbFlash than what is commonly available (3.04), and was (accidentally?) Included by a vendor in a piece of software that shouldn't really need it. It's possible that it will be removed from the software after it becomes known that it's in there, so if this interests you don't delay in securing yourself a copy. There is a changelog included, and the updates have fixed a couple of minor bugs and added support for newer hardware. So without further delay ...
... the software is Gigabyte RGB Fusion 2.0, specifically the release contained in "RGB_Fusion_B20.1210.1.zip"
You will either have to unpack the installer, or actually install it and look for the "AtiTool" subdirectory inside of where the program is installed. (Caution when doing this, as RGB Fusion 2.0 will install a lot of drivers that you probably don't want)
Small update - so it turns out this version is limited in at least one way. It will not let you force flashing through an SSID mismatch. Example output below:
This behaviour is exactly the same as the version of AMDVbFlash that is already commonly floating around, so this is not a new issue I guess
Code :
AMDVBFLASH version 3.15 EXTERNAL, Copyright (c) 2020 Advanced Micro Devices, Inc.
-f option not support in external version of the tool. Please refer to tool help for list of option supported
Old SSID: 230C
New SSID: 2308
SSID mismatched
   ERROR: 0FL01
