Question More Power Tool + Asus RX580 - "not supported"
martini
Hi,
I'm trying to load Asus rog strix RC580 bios to MPT software, but I'm getting "not supported" error. Anybody have solution for this problem?
  • BIOS_RX_580_Asus_ROG_Strix_Top_OC (4).rom
hellm
Yes, try RBE. MPT doesn't support Polaris, the PowerPlay table on Polaris isn't that powerful anyway.
With RBE you have a lot of options, i recommend to also change the memory timings to "UberMix".
martini
Thank you. RBE opened it without problem.
Where I can find "UberMix" timings?
I want to set Gpu voltage to 1200 mV. What should I put in "65288" heading? rbe_bios.JPG
hellm
As far as i know, those are only pointers to values in a subtable. And with recent, or not ancient driver versions, they are obsolete, don't work anymore. So you have to use the offset or just the min and max values.
For UberMix, look for the Polaris BIOS Editing thread on overclock.net.
For further questions ask for mynm (@..) here in the forum community.
