floppy525
- Mitglied seit
- Feb 7, 2021
- Beiträge
- 3
- Bewertungspunkte
- 0
- Punkte
- 2
Hi all,
I want to say a big thanks (Velen Dank!!!) to the information and tools given here. I have managed to flash my card and running stable for both gaming and mining.
Mining profile
As for the ROM, I found a Russian site which contains it: https://bitby.ru/bios-rx5600xt-mod-en.php
Here is the VRAM timings (Red BIOS Editor) it used for the (Gigabyte RX 5600 XT 6 GB WindForce OC GV-R56XTWF2OC-6GD/F3/0A03 Micro) :
I have also attached my slightly modified MPT profile here. The Memory Maximum Clock (Mhz) is only 937 Mhz because the balance is good for my card.
Usual disclaimer applies, I am not responsible for anying you do/ dont do with this information
Good luck and have fun!
Mining profile
Eth speed: | ~43 MH/s |
GPU clock: | 1015 Mhz |
Memory clock: | 1856 Mhz |
GPU Voltag: | 0.806 V |
Memory Voltage: | 0.850 V |
1000 Mhz | 40060000550C0000000000004A090000400000000F19110B28000F00040400020C0000000506060010000000218A05000000010101000101001718006C0700000A0A000078000000780000008A204C02320000000A00040A0E0300011F2A0C006E000000C2F2130F6E00000000000000 |
1250 Mhz | 0008000065000000000000005A090000400200001120150F33001300060600020C0000000507070014000000210C0600000001010100010100191800470900000A0A000096000000960000008A205C02400000000A00040A100300011F2A0C008A00000082F3130F8A00000000000000 |
1550 Mhz | 800900007D040000000000006A09000040020000142619133D00170006060002100000000508080018000000218E06000000010101000101001C1800810B00000A0A0000B4000000B40000008A206C024C0000000A00040A130300011F2A0C00A500000002F4130FA500000000000000 |
1750 Mhz | 000B00000D08000000000000EA09000040030000162C1D1747001B000808000210000000050909001C000000319006000000010101000101001E1800FD0C00000A0A0000D2000000D20000008A207C02580000000A00040A150300011F2A0C00C1000000C2F4130FC100000000000000 |
1800 Mhz | 000B00000D08000000000000EA09000040030000162C1D1747001B000808000210000000050909001C000000319006000000010101000101001E18005C0D00000A0A0000D2000000D20000008A207C02580000000A00040A150300011F2A0C00C1000000C2F4130FC100000000000000 |
1875 Mhz | C00B0000150A000000000000FA09000040030000172F1F194C001D000808000214000000050A0A001E000000311207000000010101000101001F1800EB0D00000A0A0000E1000000E10000008A2084025E0000000A00040A160300011F2A0C00CF00000002F5130FCF00000000000000 |
2000 Mhz | 800C00001D0C000000000000FA090000400300001832211B50001E000808000214000000050A0A002000000031120700000001010100010100201800D80E00000A0A0000F0000000F00000008A208A02640000000A00040A170300011F2A0C00DC00000042F5130FDC00000000000000 |
