Frage AMD RX 5700XT AE Frequency set to 300MHz
Poloasis
After a clean install of AMD Adrenalin 2020 and when I applied the write MPT SPPT, the frequency gets sets to 300MHz in Wattman. No frequency or voltage option can stick in wattman. Is the latest version of MPT compatible with Adrenalin 2020?
MPT works fine with adrenaline 2019.
Can anyone points me to a fix?
Tx.
This is driver dependend. You can't increase now the max frequency from BIOS and the maximum voltage. Same for power limit. I'm not sure if this is a bug or a new strategy.
