Question AMD Radeon Pro W5700 for mining ethereum
nivrij
I am contemplating about buying this card because someone is offering this to me for a cheaper price here where I live. From my understanding, this card is just the "professional" / "workstation" equivalent of RX 5700 XT.
Any thoughts on this card? Has anyone here actually used this for mining? Does anyone know what the hashrate is? Can an unlocked BIOS be flashed on this GPU?
Do you mean this version?
I have flashed this version but Wattman is not active in Windows.
When I read this version (105) with MPT there is no check mark.
How can I unlock the bios?
I can upload the original bios file here if you want.
It does about 50 MH/s
But this is still STOCK
I would like to overclock it better so it is important to me it must be all unlocked.
I am aware of the risk.
Are my steps I have listed above correct to unlock an original BIOS? (my post above you)
Thanks :) Stone
That's my version, locked.
Mini_me unlock 102 version is this: https://www.igorslab.de/community/attachments/m-amd-w5700-v49-rom.11302
It's linked above on Mini_me post. Level_free user got 55MH/s with that version.
I also have 50MH/s @ 109W stock. Is you stock BIOS also 105?
Ok thanks for the info
I have obviously 105 BIOS
However when I want to install the Mini_me unlock 102 BIOS I get an ERROR.
(see screenshot)
Is it not possible to flash one from 105 to 102 ?
Or is still an additional UNLOCK necessary?
With the command = amdvbflash -unlockrom 0
How can I fix the problem ?
Thanks for the help - Stone
Hi
I created a new one 105
But i can't Flash the ROM
FLASH File = Radeon_W5700_MOD_105_by_stone.rom
I have started the unlock with the command
command.
Is that not possible ?
Thought with it the ROM is then unlocked.
Thanks for the info
  • Radeon_W5700_MOD_105_by_stone.rom
Hello
I just ordered the product
They will ship to cargo at the end of March
I bought it for mining
I hope I didn't make a mistake
I'm watching you carefully
thanks
  • Like
Bewertungen: MfA
Here the unlocked 105 version however not optimized in the kindly attached link below.
Thank you so much! I can report that it flashed successfully through HiveOS, but rig is remote and I can't reboot it right away, so I will be back in a few hours.
stone1978 - Is your GPU memory Micron? Since BIOS was successfully written to my GPU, maybe there is some difference ...
i tryed to flash but i got this error
any idea why ?
Thank you regards stone
Please download the amdvbflash v2.93+ in the kindly attached link below,
Then follow the guide below,
For flashing you can follow the method below,
- By Windows,
I. Extract the downloaded amdvbflash Tool and put it with the vbios file in a folder inside drive C,
II. Boot to windows safe mode,
III. Run as an administrator the CMD (Command Prompt) and navigate to amdvbflash folder using
cd "copy and paste folder path when you are inside the folder, for e.g., C:/293plus"
and flash the vbios following the commands below by using amdvbflash:
amdvbflash.exe -i
Press Enter
It will show you the gpu adapters list occupying the pcie slots for an example if there is only one gpu then its adapter number will be 0.
amdvbflash.exe -unlockrom 0
Press Enter
It will unlock the gpu for flashing if it is locked.
amdvbflash.exe -p 0 BiosName.ROM
Press Enter
To flash the bios, to force flash put
-f before 0,
IV. Wait for the update to finish and reboot.
  • Like
Bewertungen: MfA
For optimizing the vbios please follow the guide in the kindly attached link below,
Good morning
Well, I have already been able to flash from 102 to 105.
That was this version
There is MICRON in the file name yes
Where can I read the memory manufacturer in GPU-Z I can not find?
GPU-Z Screenshot from my w5700
Regards Stone
I just have to solve the problem how to flash the bios first
Have of course used the version 293plus.
I think I must first find out which memory manufacturer I have.
Thanks for the help :)
- By Windows,
amdvbflash.exe -i
Press Enter
Press Enter
Press Enter
-f before 0,
Hi
Thanks I will try this when I know what memory type the graphics card has.
I would like to clarify this beforehand. What tool can I use to determine the memory manufacturer?
Here is the ORIGINAL STOCK BIOS of the w5700 that I saved before the first flash.
Thanks Stone
  • Radeon_W5700_orig.rom
