Question AMD Radeon Pro W5700 for mining ethereum
nivrij
I am contemplating about buying this card because someone is offering this to me for a cheaper price here where I live. From my understanding, this card is just the "professional" / "workstation" equivalent of RX 5700 XT.
Any thoughts on this card? Has anyone here actually used this for mining? Does anyone know what the hashrate is? Can an unlocked BIOS be flashed on this GPU?
alvaro
Hi, is this Mini_me's BIOS or the modified version from Beast819 in Posting #362?
What ist your ambient temperature? And is this a Samsung or Micron card?
@totolin8, whats your opinion now about Beast819's BIO
@totolin8, whats your opinion now about Beast819's BIOS?
I use the bios from post #137,
Im in a warm weather, around 28°C.
I have micron memory
alvaro
i just replace all thermal pads (Gelid ultimate), 1,5mm fot rams, and 1mm for the other parts but now i have a hotspot 105`C,
Core: 51°C, HotSpot: 105°C, Mem: 60°C, Fan: 48%, RPM: 2254 (Started to mining and quickly i stoped the miner)
i opened it again but i cant find the problem.
can u report u hotspot?
where could the problem be?
Xan27
Maybe you forget a thermal pad or its slipped?
Here are the temps of my micron card, it have the original thermal pads. My ambient temperature is ~25°C.
I have some cards with samsung memory too, they dont need 100% fanspeed for 76°C memory temperature.
alvaro
thanks for quick answer. I just fixed it.
I made a fast, cheap and effective solution. I just cleaned the chip and apply a thin thermal paste over it without remove the graphite pad from the dissipator. and the results...
Core: 56°C, HotSpot: 66°C, Mem: 70°C, Fan: 50%, RPM: 2346
The next time it opens it will be a mess. I hope it is not soon.
