Question 5600XT BIOS flashed with mod from Red BIOS Editor, there is an issue
ricardo
Hello and thank you for everything. Currently, I have a 5600XT in which I have flashed the modified bios by Red BIOS Editor. However, the BIOS did not work, the system hangs during POST. This is no problem, I am used to flashing BIOS with SPI Programmer CH341a, I am free to test anything.
I think maybe this did not work due to the fact that my card is dual BIOS, and when I read the BIOS from the memory chip, it comes out with 1024kb, rather than the 512kb saved from GPU-Z. When I try to open this extracted BIOS with RBE, it modifies fine, but does not save by stating "An unknown error occurred when accessing (filename path). This is not a permission issue, I am running admin. It works fine to save the file when I use the GPUz extracted rom. However, even with the 512KB file, it does not work to post the card.
I have tried several things, the last one was to make only a very small change on the GFX Maximum Clock to 1900MHz. It still does not work. I originally made a BIOS with a lot more changes and limits, such as 2100, 1000 memory, more power, voltage, etc, etc. but decided to make a small alteration to see if it would work-- unfortunately it doesn't.
I have also tried to open in HxD the original long file 1024kb and noticed it makes no difference, because after 000FFFF0 it is only 0's anyway. Also, in HxD, I have tried to open the original stock BIOS and overwrite the part, leaving the correct file size, but this also did not work to POST. Stock BIOS still works fine when re-flashed, card is perfect.
So, I am leaving a link to my files, to see if we can figure out why the modified BIOS is not working on my 5600XT.
Here is the URL: http://xonedigital.com/BIOS_etc.zip
on this ZIP file, there are the following:
1 - 5600xt1_gpuz.rom (Original BIOS from the card extracted with GPU-Z)
2 - 5600xt-stock_extract.rom (This is the BIOS file extracted from the Chip with SPI Programmer, it loads on RBE, but fails to save)
3 - mpt-1900_only.mpt (This is an example of a small change I tried to see if it would work, only changing maximum clock to 1900mhz)
4 - 1900-ONLY-BIOS1.rom (This is the final outcome of RED BIOS EDITOR using the GPU-Z BIOS with the MorePowerTool settings of 1900mhz)
I hope this helps, thank you so much for all your work again and let me know if anything else is needed. I am really looking forward to free up the power of this 5600XT :)
Thanks again!
Hi guys, so I don't do a vbios flash for a couple years now and seems this is getting harder. I am failing to mod my Sapphire 5600XT, seems that I cant get it to boot with the modded bios, always get a black screen and a fail white led from the motherboard. I upload here the default BIOS if someone can have a look. Thanks
General
Version 017.001.000.068.000000
Build Date 2020-05-17 23:31
Part # 113-5E4117U-X4H
GPU NAVI10
Bus PCI_EXPRESS
Memory GDDR6
Bootup Message NAVI10 A1/A2 E417 XLE 6GB 300e/875m 5HP
Filename 417EFMIU.X4H
Changelist 2116765
Build # 515998
Config File SAPPHIRE_NAVI10_E417_XLEOC_A2_MI_6G_160W14G5HP\config.h
Edit: no longer necessary.
Hello, I am looking for unlocked BIOS for Sapphire Pulse 5600XT , the Tripple Display port version, aka 3DP, with dual BIOS, SKU number:
#11296-01-20G
ProductNumber:
PN S88-4e426-210SA
Sapphire Pulse Radeon RX5600 XT6G GDDR6 HDMI/TRIPPLE DP OC W/BP (UEFI)
Board ID: 113-4E4262U-X4Q
If anyone has unlocked BIOS or similar compatible BIOS for Sapphire 5600XT, please send PM or write in this topic.
The new GPU prices are outrageous and I need an FPS boost in one of my games...
Thank you in advance!
And here is the original BIOS, from my card!
MIRROR:
Fantastic, since the latest 2 RBE Beta versions no longer u guys need to ask for a unlocked Bios, since they included into RBE itself.
So thanks for the RBE developers for made that so easy.
I need help!
- I need Original BIOS for MSI 5600XT Gaming MX, using Samsung K4Z80325BC memory.
Can someone share it with me, please!
Muchas gracias a sir [ USER = 5105 ] @ Mini_Me [ /USER ] por ayudar a desbloquear mi Sapphire Pulse 5600xt BE. Necesito más ajustes, pero este es el más alto que logrado en el ataque con fuego. Mi punto de ataque de fuego suele ser 194xx con punto de gráficos 22xxx.
[ ADJUNTAR = completo ] 11527 [ / ADJUNTAR ]
Hello, would you have the bios for the rx5600xt BE unlock? , thank you
Hallo, hätten Sie das BIOS für den RX5600xt BE unclok? , Danke
Thank you so much to sir @Mini_Me for helping unlock my Sapphire Pulse 5600xt BE. I need more tweaking but this is the highest i have ever achieve in firestrike. My firestrike score is usually 194xx with 22xxx graphics score.
Hi @Mini_Me
could you please send me an unlocked Sapphire 5600 XT Pulse BE ROM (Micron)? I've seen you'd already backed that BIOS for some folk. For gaming purposes.
Thank you.
