Question 5600XT BIOS flashed with mod from Red BIOS Editor, there is an issue
ricardo
Hello and thank you for everything. Currently, I have a 5600XT in which I have flashed the modified bios by Red BIOS Editor. However, the BIOS did not work, the system hangs during POST. This is no problem, I am used to flashing BIOS with SPI Programmer CH341a, I am free to test anything.
I think maybe this did not work due to the fact that my card is dual BIOS, and when I read the BIOS from the memory chip, it comes out with 1024kb, rather than the 512kb saved from GPU-Z. When I try to open this extracted BIOS with RBE, it modifies fine, but does not save by stating "An unknown error occurred when accessing (filename path). This is not a permission issue, I am running admin. It works fine to save the file when I use the GPUz extracted rom. However, even with the 512KB file, it does not work to post the card.
I have tried several things, the last one was to make only a very small change on the GFX Maximum Clock to 1900MHz. It still does not work. I originally made a BIOS with a lot more changes and limits, such as 2100, 1000 memory, more power, voltage, etc, etc. but decided to make a small alteration to see if it would work-- unfortunately it doesn't.
I have also tried to open in HxD the original long file 1024kb and noticed it makes no difference, because after 000FFFF0 it is only 0's anyway. Also, in HxD, I have tried to open the original stock BIOS and overwrite the part, leaving the correct file size, but this also did not work to POST. Stock BIOS still works fine when re-flashed, card is perfect.
So, I am leaving a link to my files, to see if we can figure out why the modified BIOS is not working on my 5600XT.
Here is the URL: http://xonedigital.com/BIOS_etc.zip
on this ZIP file, there are the following:
1 - 5600xt1_gpuz.rom (Original BIOS from the card extracted with GPU-Z)
2 - 5600xt-stock_extract.rom (This is the BIOS file extracted from the Chip with SPI Programmer, it loads on RBE, but fails to save)
3 - mpt-1900_only.mpt (This is an example of a small change I tried to see if it would work, only changing maximum clock to 1900mhz)
4 - 1900-ONLY-BIOS1.rom (This is the final outcome of RED BIOS EDITOR using the GPU-Z BIOS with the MorePowerTool settings of 1900mhz)
I hope this helps, thank you so much for all your work again and let me know if anything else is needed. I am really looking forward to free up the power of this 5600XT :)
Thanks again!
Hello Mini_Me,
Could you help me unlock my bios for Asus Strix O6G 5600xt micron. Here's the stock bios from gpu-z. bios v is 017.001.000.049.000000.
Thank you in advance.
  • Navi 10.rom
Hello Mini_Me,
Red Bios Editor should be able to unlock a lot if not almost all RX5600XT bios!
Game over for me. My MSI Gaming X RX 5600 XT, has been bricked! It acts like bad hardware, I can't for the life of me to get the PC to boot, even with another card in one of the PCI-E slots. :( RIP RX 5600 XT (sometime in November, 2020-December 24, 2021)
This can happen of course sometimes. I can’t recommend to flash any VBios from a different card.
where are you from ? @RJARPCGP
I'm from Springfield, Vermont, U.S.A. This was with an attempt to flash the VBIOS I extracted from GPU-Z!
Because I can't get in to the system, even with it as a secondary card, it became a for-parts card. I scavenged thermal pads to address an issue with eVGA GeForce GTX 1060s. The one that I bought on November 5, 2016, needed thermal pads for the VRAM and other stuff.
Also the VBIOS I had, was taken down from the hoster or disabled by the hoster. I tried to download it again a while ago, because I can't find it on my USB sticks!
I saved the VBIOS and only used the VBIOS I got extracted via GPU-Z. But this time, it's like the Radeon team gave me the middle finger!
I really am that miffed!
Looks like for a while, I'll be trying to get a mod for the RX 5500 XT, as it lets me OC alright, but gets unstable! It acts much like an old card, where the stock VBIOS will actually let me clock it too high by accident and presto, a crash, an error or video corruption!
In the case of the RX 5500 XT, it looks like I possibly don't have enough GPU Vcore. Like the RX 5600 XT, that's definitely locked!
Need a VBIOS mod to unlock the Vcore.
RIP RX 5600 XT!
Hi Mini,
I have a Sapphire pulse 5600xt, PN 299-4E411-002SA, SKU#11296-01
Unfortunately i have lost both stock bios when i flashed one that draws too much power while mining.
Could you please help with the unlocked stock bios please?
Not in my case, I feel like a mistake I made, was not using the beta version, albeit it looked like it was updated. The RX 5600 XT, is a goner!
Wow, so many posts regarding this! @minimmi @mini Mi, I dont know if you can also help me. My ASUS ROX 5600xt keep crashing and I want to bios mod but all bios dont want to boot.
Attached are my original bios and modified bios
  • MODIFIED2 BIOS ROG STRIX 5600 AMD.rom
  • Original2 BIOS ROG STRIX 5600 AMD.rom
Good day,
I´m trying to mod my bios of a Asrock RX 5600 XT 6 GB Challenger D 113-EXT40650-001 - NAVI10 A1/A2 D18901 XLE 6GB 300e/750m Samsung + Micron
I tried to reach Bitby but looks like still in vacations :)
I follow the article about MPT and RBE but looks like I´m failing in something, after a success vbios download on HiveOS the miner TRM shows openCL error and I have to return to stock Bios, it happens with little changes on MPT or RBE, Does anyone have an idea what I might be doing wrong?
I would like to increase my MHs and down watts, I saw couple tuning where you can get 42MHs @ 80w
thanks in advance
  • stock5600.rom
hey mini! i have an problem with my asus tuf rx5600xt i cant patch anybios. giving me unknown memory and no display. can you unlock the rom pls. thank you somuch i stuck at 38mh i need it for mining
p/n
Radeon RX 5600 XT 6128 MB · ASUS
Micron GDDR6 · 115-D182PI0-100
  • Rig_4779620-1-RadeonRX5600XT-6G-Micron_GDDR6-115-D199PI0-101.rom
Hello @Mini_Me,
I've tried to flash my Radeon RX 5600 XT 6128 MB · ASUS Micron GDDR6 · 115-D182PI0-100 with multiple BIOS found on the internet and I've tried to modify the stock one, but nothing seems to work.
Could you unlock the bios? I would be very greatful.
  • rigE53BD7-4-RadeonRX5600XT-6G-Micron_GDDR6-115-D182PI0-100.rom
Hi mini_mi , would you possibly be able to help with the bios for my 5600xt . i tried the flashing/modding hasnt seemed to make a difference to hashrate...... its a asus rog strick top . Is it due to being locked or have i dont something wrong ???
  • ASUS-Radeon-RX-5600-XT-6GB_115-D182PI0-100-stock.rom
@Mini_Me
I already sent you the unlocked vbios.
I need some help here too I managed to buy a new 5600xt last week, I paid $10 to get an unlocked Rom to Bitby but after 5 days I have heard nothing back from him any chance you could unlock one for me. I hate to ask but want to get as much out of the card as I can while I can.
  • TheSluiceIsLoose-6-RadeonRX5600XT-6G-Samsung_GDDR6-113-MSITV381MH.3HO.rom
@Mini_Me
Hello, im trying to unlock the asus rog-strix-rx 5600 xt-t6g-gaming samsung memory for mining but even i try it crashes, can u helpe me ?
  • asus rog-strix-rx 5600 xt-t6g-gaming.rom
Hello I need stock silent bios for this card : RX 5600 XT Red Devil . I try find on website,but nothing. Official page powercolor haven't bios to download.. Every bios from techpowerup is unstable for me. GPu is from second hand. In windows is stable. but in 3d app dump. (Black screen,artifact) I search stock bios to flashed. Some help me please ? THANK YOU !
