Question 5600XT BIOS flashed with mod from Red BIOS Editor, there is an issue
ricardo
Hello and thank you for everything. Currently, I have a 5600XT in which I have flashed the modified bios by Red BIOS Editor. However, the BIOS did not work, the system hangs during POST. This is no problem, I am used to flashing BIOS with SPI Programmer CH341a, I am free to test anything.
I think maybe this did not work due to the fact that my card is dual BIOS, and when I read the BIOS from the memory chip, it comes out with 1024kb, rather than the 512kb saved from GPU-Z. When I try to open this extracted BIOS with RBE, it modifies fine, but does not save by stating "An unknown error occurred when accessing (filename path). This is not a permission issue, I am running admin. It works fine to save the file when I use the GPUz extracted rom. However, even with the 512KB file, it does not work to post the card.
I have tried several things, the last one was to make only a very small change on the GFX Maximum Clock to 1900MHz. It still does not work. I originally made a BIOS with a lot more changes and limits, such as 2100, 1000 memory, more power, voltage, etc, etc. but decided to make a small alteration to see if it would work-- unfortunately it doesn't.
I have also tried to open in HxD the original long file 1024kb and noticed it makes no difference, because after 000FFFF0 it is only 0's anyway. Also, in HxD, I have tried to open the original stock BIOS and overwrite the part, leaving the correct file size, but this also did not work to POST. Stock BIOS still works fine when re-flashed, card is perfect.
So, I am leaving a link to my files, to see if we can figure out why the modified BIOS is not working on my 5600XT.
Here is the URL: http://xonedigital.com/BIOS_etc.zip
on this ZIP file, there are the following:
1 - 5600xt1_gpuz.rom (Original BIOS from the card extracted with GPU-Z)
2 - 5600xt-stock_extract.rom (This is the BIOS file extracted from the Chip with SPI Programmer, it loads on RBE, but fails to save)
3 - mpt-1900_only.mpt (This is an example of a small change I tried to see if it would work, only changing maximum clock to 1900mhz)
4 - 1900-ONLY-BIOS1.rom (This is the final outcome of RED BIOS EDITOR using the GPU-Z BIOS with the MorePowerTool settings of 1900mhz)
I hope this helps, thank you so much for all your work again and let me know if anything else is needed. I am really looking forward to free up the power of this 5600XT :)
Thanks again!
Please choose the appropriate vbios in the kindly attached link below,
Thanks Mini_Me
When I try this i get a SSID Mismatch:
Old SSID: 2313
New SSID: 2321
Is it compatible?
Could someone please optimise this .rom and .mpt for me?
I have Power Color Red Devil 5600XT, my goals is to get 2,1Ghz Core clock boost, i've tried it . And memory maybe 1860mhz ?
Power limit can be 200-225W, curvature I don't know maybe at 2,1ghz/1170 mV?
Please.
  • rx5600xt.zip
Please.
You can do it yourself, please follow the guide in the kindly attached link below,
Видеокарта ASUS Radeon RX 5600 XT 6Gb GDDR6 192bit HDMI 3xDP HDCP TUF 3-RX5600XT-T6G-EVO-GAMING -память samsung
  • 5600-5700-2-RadeonRX5600XT-6G-Samsung_GDDR6-115-D189P00-100.rom
Hello,
could you please send me an unlocked Sapphire 5600 XT Pulse BE ROM (Micron)? I've seen you'd already backed that BIOS for some folk. For gaming purposes.
Thank you.
I am a little confused about this bios mod, do you use the red panda bios to trick the card into allowing a custom bios then install a bios modded with morepowertool to allow the higher core clocks?
Or is their something else to it?
AsRock RADEON RX 5600XT Challenger Pro 6G OC 6GB GDDR6 192bit 3xDP HDMI RX5600XT CLP 6GO - память samsung
Не могу найти биос, может кто поможет? или что-то подсказать?
Видеокарта ASUS Radeon RX 5600 XT 6Gb GDDR6 192bit HDMI 3xDP HDCP TUF 3-RX5600XT-T6G-EVO-GAMING -memory samsung
Hi Mini_Me, can u please unlock the bios for my ASrock Challenger D rx5600XT ?
I want it only for gaming, just need an 10% bump on performance to get 144fps stable.
Thanks, ive extracted it using GPU-Z, its ok?
Best regards. :)
  • ASRock Challenger D RX 5600 XT default.rom
Hi Mini_me, can you please unlock my bios for my asus ROG-STRIX-RX5600XT-T6G-GAMING
Thank you so much!
  • Asus_ROG-STRIX-RX5600XT-T6G-GAMING.rom
Just came to thank Mini_Me for his work, works perfect on my card. Waited too many months for this to happen, thank you! :D
Now i need a new PSU, mine is not enough for a 200w card :p
Hi Mini_Me, thank you so much! thats super quick! You're awesome to be doing this. Btw, if I modify memory timings using red bios editor, do I leave the selector on 5700 instead of 5600xt? Also do I flash using 3.04+ or 2.93+?
Hi and welcome,
The gpu-id is already changed to 5700,
You can use any of the tools however 3.04+ is preferred when flashing RX 5600 XT cards.
ok thanks for the info. One last quick question. For DramTiming12 Tref i have seen some people set to 8500 all the way up to 9900. What is optimal?
Shoot, i put it all the way up to 9900 when my memory clock was set to 1860. Can it damage anything? Will it degrade performance when mining?
