Question 5600XT BIOS flashed with mod from Red BIOS Editor, there is an issue
ricardo
Hello and thank you for everything. Currently, I have a 5600XT in which I have flashed the modified bios by Red BIOS Editor. However, the BIOS did not work, the system hangs during POST. This is no problem, I am used to flashing BIOS with SPI Programmer CH341a, I am free to test anything.
I think maybe this did not work due to the fact that my card is dual BIOS, and when I read the BIOS from the memory chip, it comes out with 1024kb, rather than the 512kb saved from GPU-Z. When I try to open this extracted BIOS with RBE, it modifies fine, but does not save by stating "An unknown error occurred when accessing (filename path). This is not a permission issue, I am running admin. It works fine to save the file when I use the GPUz extracted rom. However, even with the 512KB file, it does not work to post the card.
I have tried several things, the last one was to make only a very small change on the GFX Maximum Clock to 1900MHz. It still does not work. I originally made a BIOS with a lot more changes and limits, such as 2100, 1000 memory, more power, voltage, etc, etc. but decided to make a small alteration to see if it would work-- unfortunately it doesn't.
I have also tried to open in HxD the original long file 1024kb and noticed it makes no difference, because after 000FFFF0 it is only 0's anyway. Also, in HxD, I have tried to open the original stock BIOS and overwrite the part, leaving the correct file size, but this also did not work to POST. Stock BIOS still works fine when re-flashed, card is perfect.
So, I am leaving a link to my files, to see if we can figure out why the modified BIOS is not working on my 5600XT.
Here is the URL: http://xonedigital.com/BIOS_etc.zip
on this ZIP file, there are the following:
1 - 5600xt1_gpuz.rom (Original BIOS from the card extracted with GPU-Z)
2 - 5600xt-stock_extract.rom (This is the BIOS file extracted from the Chip with SPI Programmer, it loads on RBE, but fails to save)
3 - mpt-1900_only.mpt (This is an example of a small change I tried to see if it would work, only changing maximum clock to 1900mhz)
4 - 1900-ONLY-BIOS1.rom (This is the final outcome of RED BIOS EDITOR using the GPU-Z BIOS with the MorePowerTool settings of 1900mhz)
I hope this helps, thank you so much for all your work again and let me know if anything else is needed. I am really looking forward to free up the power of this 5600XT :)
Thanks again!
Ok. I just tried it. MSI Gaming MX 5600xt bios is locked. Could you unlock this one as well. I sure wished I knew what the secret sauce is that your applying to them. lol
Thanks for all your help.
  • msigaming_original.rom
Hello Mini_Me,
I have read through all 17 pages of this thread and am impressed with your generosity in providing so many bios files! It is my turn to ask... can you help me with unlocking the ASUS DUAL 5600xt bios (DUAL-RX5600XT-T6G-EVO) please. I see you may have done one above for @marcosvega2; however, I've attached the file I've extracted in case they are different. In case you need to know, I will be mining with this card.
Thanks in advance,
momanz
Another happy user here. Just flashed the modded bios and I'm seeing about a 3Mh/s improvement.
Thank-you!
Can you please unlock MSI Gaming MX 5600xt bios. It is locked as well.
@Mini_Me Any chance I could get an unlock as well?
It's also MSI 5600XT Gaming MX, but it's using Samsung K4Z80325BC memory and identifies as 113-MSITV381MH.3HO, seems different from the one posted by Zerberfert & the other unlocked versions I've seen posted around.
  • MSI-5600XT-GamingMX-Samsung-113-MSITV381MH.3HO.rom
hi
i have 2 XFX RX 5600 XT 14Gbps 6GB GDDR6 THICC III Pro , and i ask if it's possible boost them for mining more than 40.5mh
this is VBIOS extracted from HIVEOS, switch position is Performance BIOS
i suggest create a topic with all moded bios by model, it will be easy for others to find them without asking @Mini_Me everytime.
Thank you for all your help
  • 0-RadeonRX5600XT-6G-Micron_GDDR6.rom
I am trying to flash and unlock a gigabyte rx 5600 windforce GV-R56XTWF2OC-6GD / FA0 / 0A7C with micron memories,
and the error jumps
Old SSID: 231D
New SSID: 231D
BIOS authentication signature mismatched
ERROR: 0FL01
both in linux and windows
I only managed to flash by amdvbflash 293+ on windows, but it wouldn't start
even replacing the sub vendor and the sub id of the new bios, it does not flash
Someone else happens ?
the bios I'm trying to flash is that msi, from reddit
@Mini_Me Sorry to bother you im doing a little bit of experiments with my Sapphire Pulse 5600XT, it's micron and im going to use it for gaming, could you please unlock the limits to overclock?, i just discovered that this card can be "unlocked" i have this BIOS file that i extracted with TRIXX Boost, the switch was in Silent position, i have the one that comes with the 14gbps memory bios update already. those files are the two bios of my particular model, thanks in advance ><
  • Silent bios.rom
  • Perf bios.rom
Please could provide the P/N for your card.
Jungs, habt ihr einen BIOS Mod für POWERCOLOR 5600XT Red Dragon 6GB? Samsung RAM, BIOS 113-D189XLE
sory für deutsch, google translate :)
Oh yeah sorry for the confusion, that's was what I was referring, I saw earlier on the thread that someone asked you to unlock the Red Devil 5600 XT, and I was wandering if you could send me a copy too. If I misunderstood could you help me unlock the original one?
Thanks in advance and sorry for bothering you.
  • OC.ROM
  • silent.ROM
Hi @Mini_Me, Can you help me with the bios of a AsRock Challenger Pro with Samsung memory? I want to use it for mining but when I change the VBios it make crash my motherboard and don't let me even to enter the MB Bios.
  • Original_Radeon-RX-5600-XT-6GB_113-EXT800128-L02.rom
Hi @Mini_Me , i would need help with this bios if you have the time. I just cant make any bios to work on the card except the original one. If you could please unlock this for me, i am trying to make a bios to mine on the asus rog strix gaming 5600xt TOP. part number is rog-strix-rx5600xt-t6g-gaming. I would really appreciate your help. Thanks
  • originalbios.rom
