Question 5600XT BIOS flashed with mod from Red BIOS Editor, there is an issue
ricardo
Hello and thank you for everything. Currently, I have a 5600XT in which I have flashed the modified bios by Red BIOS Editor. However, the BIOS did not work, the system hangs during POST. This is no problem, I am used to flashing BIOS with SPI Programmer CH341a, I am free to test anything.
I think maybe this did not work due to the fact that my card is dual BIOS, and when I read the BIOS from the memory chip, it comes out with 1024kb, rather than the 512kb saved from GPU-Z. When I try to open this extracted BIOS with RBE, it modifies fine, but does not save by stating "An unknown error occurred when accessing (filename path). This is not a permission issue, I am running admin. It works fine to save the file when I use the GPUz extracted rom. However, even with the 512KB file, it does not work to post the card.
I have tried several things, the last one was to make only a very small change on the GFX Maximum Clock to 1900MHz. It still does not work. I originally made a BIOS with a lot more changes and limits, such as 2100, 1000 memory, more power, voltage, etc, etc. but decided to make a small alteration to see if it would work-- unfortunately it doesn't.
I have also tried to open in HxD the original long file 1024kb and noticed it makes no difference, because after 000FFFF0 it is only 0's anyway. Also, in HxD, I have tried to open the original stock BIOS and overwrite the part, leaving the correct file size, but this also did not work to POST. Stock BIOS still works fine when re-flashed, card is perfect.
So, I am leaving a link to my files, to see if we can figure out why the modified BIOS is not working on my 5600XT.
Here is the URL: http://xonedigital.com/BIOS_etc.zip
on this ZIP file, there are the following:
1 - 5600xt1_gpuz.rom (Original BIOS from the card extracted with GPU-Z)
2 - 5600xt-stock_extract.rom (This is the BIOS file extracted from the Chip with SPI Programmer, it loads on RBE, but fails to save)
3 - mpt-1900_only.mpt (This is an example of a small change I tried to see if it would work, only changing maximum clock to 1900mhz)
4 - 1900-ONLY-BIOS1.rom (This is the final outcome of RED BIOS EDITOR using the GPU-Z BIOS with the MorePowerTool settings of 1900mhz)
I hope this helps, thank you so much for all your work again and let me know if anything else is needed. I am really looking forward to free up the power of this 5600XT :)
Thanks again!
vibes31fr
Hello Mini_Me,
Thank you for your work. I work also on sapphie pulse 5600xt but with redpanda bios.I can achieve little more 44mh/s at 1860MHz with other timing but i have some issue. My card is stable sometime for some days, sometimes only few hours.
I think redpand bios isn't better for sapphire.
I want test your bios with my timing and your powerplay table and the good bios for sapphire.
Apple timing is good but not the best. I try a mix 1550MHZ strap and apple timing to 1800 and 1875MHz.
I want play on features with your bios(acdc activate is good idea and desactivated all Vrhot). Sapphire have a security. I can have more 1860MHz but GFX reset at minimum level. So, this card can achieve between 45-50MH/s but we need find where is all security for mining;)
PS : Sorry for my english.
You are the best for unlocked bios!!!! I try this since long time for sapphire.
artolive
Merhaba [USER = 5105] @Mini_Me [/ USER]
Nazik yardımlarınız için teşekkürler ...
Amatör bir madenciyim :) ve kartlarımı değiştirmeye ve OC yapmaya çalışıyorum ...
5700'lerim ve 5600 xt'lerim için RedPanda modları yapmaya çalışıyorum.
Tüm 5600XT'lerim başarısız oldu ... Orijinal modları kullanıyorum ...
Ve 5700xt'ler henüz güçlü değil ... Belki OC ayarlarından dolayı ...
Öncelikle OC ayarları için Rigs ScreentShots'umu paylaşmak istiyorum.
SimpleMining kullanıyorum
2 Rig'im var ve TeamRedMiner kullanıyorum.
4GB Kart çok önemli değil ama paylaşacağım ...
OC Ayarlarım.
Ve bu İkinci donanım önemli çünkü tüm kartlarım 5700 5700xt ve 5600 xt ...
Bu iki GPU'da ÖLÜ GPU Hatası var ve diğer gpuslar düşük MH Gücü
MY Second Rig OC Ayarları ...
Ve son olarak, yardımınız için orijinal biyografilerimi ekleyeceğim ... Belki bazıları aynı ama tüm orijinallerimi yükleyeceğim ...
PS. Kötü İngilizcem İçin Üzgünüm
Bazı değiştirilmiş dosyaları ve OC ayarlarını paylaşabilirseniz, minnettar olurum
Forum, dm veya mail yoluyla iletişime geçebilirsiniz ...
arto @ davulciyan . com <3
My Orginal Bios Files: https://easyupload.io/xxbhst
MrAlex-Cabessa
Olá, bom trabalho pessoal, alguém tem uma BIOS de desbloqueio para ASUS RX5600XT DUAL EVO TG6? Eu li todo o tópico de 1 a 15 e apenas encontrei o arquivo da bios original para este modelo, obrigado!
artolive
OC Ayarlarım.
Hi @Mini_Motz When you have time could you check my settings?
I'm in trouble
Mini_Me
I'm in trouble
Hi and welcome,
For your RX 5700 XT and non XT cards please check the guide in the kindly attached link below,
For your 5600 XT cards I will unlock it for you and then you can use the guide provided above for non XT with the only changes below,
- Under Feature Control, set:
DPM_GFX_PACE: Check (Enable),
To keep the ratio of Core clock to VDD = below 2.00 (preferred 1.9, default is 1.80) and please remember the minimum stable VDD is 750 mV.
nzmartinM
Greetings and welcome,
Send your card vbios backup and even if it does not have Micron memory type still I may be able to help in unlocking your vbios for modifying, however it might take a bit of time.
@Mini_Me Greetings,
When you have the chance. I have two cards for mining, but fail to mod the bios. Could you help out please?
Asus rog strix, 1002 731F - 1043 04EC
Sapphire Pulse BE, 1002 731F - 1DA2 E416
Much appreciated.
Martin
  • Asus5600Org-SILIENCE.rom
  • Sapphire5600Org.rom
MrAlex-Cabessa
Thanks to @Mini_Me I managed to unlock my BIOS. In Adrenalin the most stable configuration I found was,
GPU Frequency - MHZ: 2073
Voltage: 1100
VRAM - mhz: 1820
Power Limit: 25%
GPU MODEL - ASUS DUAL 5600XT EVO
Marko
Hi all,
I have 3 diffrent AIB gpus that i would like to use for mining but cannot unlock them, can someone please help me unlock them or mode them for mining(lower voltage limit and custom straps)
TNX
  • Sapphire5600XTPulse_Micron_orig0.rom
  • Asrock5600XTChallangerProOC_Micron_orig0.rom
  • MSI5600XTGamingX_Micron_orig0.rom
Marko
Just wanted to say BIG TY Mini_Me
Followed ur step by step guide for 5700 with applying difrences for 5600XT, got 43.3MHs with 1235MHz core, 935MHz Micron memory, 700mV vcore, 1350mV for MVDD , 875mV for MVDDCI.
Used straps for Micron vram from that .txt file.
Power consumption when card is idling(not mining) from wall 71W, when mining 170W
My question is, since that guide is for 5700 gpus, can I go lower with core clocks and voltages since it has only 192bit bus width(maybe no need for 1235MHz core)?
and
can I try to use custom straps with diffrent tref value)?
Ty again
Mini_Me
Followed ur step by step guide for 5700 with applying difrences for 5600XT, got 43.3MHs with 1235MHz core, 935MHz Micron memory, 700mV vcore, 1350mV for MVDD, 875mV for MVDDCI.
Power consumption when card is idling (not mining) from wall 71W, when mining 170W
My question is, since that guide is for 5700 gpus, can I go lower with core clocks and voltages since it has only 192bit bus width (maybe no need for 1235MHz core)?
other
Ty again
Please use the power limit below,
TDP 120 W
TDC GFX 120 A
TDC SoC 12 A
JDFFuzz
Greetings Mini_Me can you please unlock my vbios for my Red Devil 5600xt's? They are used for mining. Thanks in advance!
  • OC.ROM
  • silent.ROM
Marko
[For optimal hashrate, keep the gap between the core clock and memory clock at 480 MHz]
Does this also apply for 5600XT or this gap can be smaller(for example mem clock 920MHz, core clock 1100MHz) due to 192bit bus width that 5600XT has.
